04-23-2019 01:39 AM - edited 01-05-2022 04:31 AM
I sucessfully bought the 1GB add-on and its not working. I have no data. It's been 5 days since I bought it and the monthly renewal is coming up in a few days. I am a little peeved to say the least!
1. My account "overview tab / webpage" say's:
2. *HOWEVER*, the "Plans & Add-on tab / webpage" say's:
3. Also, the billing transaction history shows the $30 add-on was purchased.
I have an iPhone XR.
04-23-2019 08:16 AM
Double check you don't have your iPhone setup to halt data after x number of usage in a cycle - The device may be blocking you.
04-23-2019 02:34 AM
Try the lost / stolen trick. Log into self serve. Click Plans & Addons. Click Lost/Stolen phone. Click Suspend service. Log out of self serve. Reboot phone. Wait 10 minutes. Log back in. Go back to the same place and say found phone. Reboot phone. If this doesn't work the you will need to contact a moderator.
04-23-2019 02:27 AM
You will probably need to contact a moderator.
Send a private message through the following link :
Please include in the private message your phone number, account number and PIN code.
04-23-2019 02:11 AM
Tried the APN settings - no luck.
04-23-2019 02:10 AM
Thanks for the input. Yes, data was working until I used it up and had to buy more.
Data/Add-ons section does not show data remaining.
04-23-2019 01:49 AM
@steering wrote:I sucessfully bought the 1GB add-on and its not working. No data. ??
If you log into your self serve account, does it show that you have remaining data in your account under My Data & Add-Ons? I realize that you never used it. If it does show data remaining, this is likely and APN setting issue. Have you ever had data working on this phone/device?
Here's are some generic APN setttings as provided by Public Mobile: https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/How-do-I-set-up-data-APN-on-my-smartp...
04-23-2019 01:48 AM
@steering Is your data turned on? If yes, you might need to adjust your APN settings. To do that, follow this link and set the apn as listed: https://apn-canada.gishan.net/en
