1G roaming rewards add on.
05-28-2022 12:12 PM
Beware that when you use this and your USA plan renews before your 10days is up pm will systematically start using your plan roaming making you loose what’s left on what you purchase. Many of you know this and what issues I have, now pm refuses to do anything.
Add-Ons
05-29-2022 09:03 PM
The escalation department was unwilling to apply the workaround? I understand your frustration. It's beyond me that you and pm were able to work out a solution to your issue that was satisfactory for both parties and now they renege on that agreement. This allowed pm to avoid a CCTS complaint and the associated fees they have to pay and the negative statistics the accrue.
I know the basics of your issue. I will do some research for you regarding your issue and lay out a course of action for a CCTS complaint. If they rule in your favour and the workaround or a different solution is agreed upon then in the future pm will not be able to renege on your agreement. The outcome will likely be the same....why pm would rather go thru the time and expense on their part to fight a complaint than use the workaround makes for a ridiculous policy other than the hope that you wint fight for your rights as a customer.
I will contact you via private message in the next few days with the research I gather on your issue.
To contact customer support : Submit a support ticket via SIMon the chat bot Click here
Or if you cannot submit a ticket via SIMon then Click here ....for additional member supplied info.
05-29-2022 09:33 AM
@mellondon wrote:So yes I do have the grandfathered plan and you mention that I can renew early, how do I do that? That’s a great suggestion
You will need to contact customer service agent to renew your plan earlier. Unable to do it yourself via self service account.
05-29-2022 05:55 AM
@mellondon wrote:Yes it was escalated but the response was the same. I’m not sure what ccts means
CCTS handles disputes between subscribers and carriers.
05-29-2022 05:44 AM
05-29-2022 05:42 AM
Because I run out of data. With the USA plane and I need to purchase additional when I run out
05-29-2022 05:40 AM
Ah, yes. It has been an ongoing issue. Very frustrating when pm doesn’t see it your way
05-29-2022 05:39 AM
So yes I do have that plan and that’s what’s happening
05-29-2022 05:36 AM
No I’m not in the USA now. But I have the grandfathered plan and my job takes me into the USA twice a week so when I run out of data I need to purchase the 1G add on roaming (which is usually around the renewal date. If I don’t use it all when my plan renews it automatically reverts back to taking the plan data instead of using up the add-on purchase when the 10 days isn’t completely used up. Seems unfair
05-29-2022 05:30 AM
05-28-2022 02:36 PM
@mellondon "Many of you know this and what issues I have, now pm refuses to do anything."
Workarounds technically available to CSAs have been withdrawn before. So, suggest you plan accordingly if PM remains unresponsive; assuming you have the grandfathered $60 USA plan, perhaps renew your plan early instead of buying data add-ons.
If you do elect to engage CCTS be prepared for a lot of aggro and, perhaps, no gain at all.
05-28-2022 01:44 PM
@darlicious wrote:If you can't be bothered to review the history then why are you even in this thread asking questions?
Harsh @darlicious.
And I might know a little about harshness.
05-28-2022 01:44 PM
@darlicious Sorry boss please don’t fire me lol
05-28-2022 01:41 PM
05-28-2022 01:37 PM
This was set up as a workaround for your plan because it was an unusual circumstance and much cheaper for them than rewriting code for each customer. Tell the CSA that you want a senior member of the team to take over your support request. If they refuse as well over to the escalations department. And I think you know what's next.....THE CCTS!
I can help with that.....
05-28-2022 12:33 PM
Yes, review OP history is a good move. But we are not full time staff here 🙂 While we try to help as much as we can and try to sick deep, OP would be nice to provide more details in a new thread
05-28-2022 12:31 PM
Hi @mellondon technically you cannot renew addon early without CS agent help. Which p
addon you got?
If it is talk and text, it is unlimited and really no reason to re-buy early.
If data, you won't re-buy unless all uses up
So, why re-buy early??
05-28-2022 12:25 PM
@dust2dust @I couldn’t be bothered to be honest with you lol
05-28-2022 12:21 PM
Please review his history here. This is a remarkable on-going quirk.
05-28-2022 12:19 PM
@mellondon - so does this mean you are on the Canada/USA calling plan (snowbirds) from a few years ago?
So if your plan renews during the 10 day roaming addon period..you are saying you lose the remaining data not used in that roaming addon at the point of renewal? Did I understand that correctly, if so, then that doesn't seem right.
05-28-2022 12:18 PM
@mellondon A little more info would be helpful I assume your in US now?
