08-15-2019 06:00 PM - edited 01-05-2022 06:26 AM
08-16-2019 08:11 AM
08-16-2019 07:51 AM
Disable your mobile data in mobile network settings, if the reason is you are afraid of over limit charge it will not happen. Your data simply stop working after your limit was used up.
08-16-2019 07:09 AM
The suggestion to disable data is fine, if the subscriber doesn’t wish to send MMS. MMS messages need data active, but do not consume data.
08-16-2019 06:40 AM
I don't think you can remove the bonus data, but I wouldn't worry about it since there are no overages.
08-15-2019 06:57 PM
Or if you are getting it for somebody underage and don't want them to use data, just run couple of speed tests after every renewal.
Alternative thing is to ask how to disable it in apn settings
08-15-2019 06:43 PM
@hairbag1 wrote:
@RossN wrote:@kfixit Hi I wouldnt worry about it just dont use it you will still get your 2 dollar autopay credit
You're entitled to the autopay credit if you use a valid credit card
on your account for future renwals. Even the $10 or $15 plans will get that credit if you use autopay. It's got nothing to do with any data.
PS...log into My Account ...click the Payment button and then Manage Autopay.
In the case of the $15 plan, data comes into the mix. When you sign up for auto pay, you get a bonus 250 mb per 30 days. The OP wanted to be excluded from the 250 mb. As others already said, OP, simply take the data and don't use it (or use it and don't worry about overages. It never hurts to have a bit of data). If you're really worried about data usage and don't need it, just disable the data connection on your phone.
08-15-2019 06:10 PM - edited 08-15-2019 06:14 PM
You're entitled to the autopay credit if you use a valid credit card on your account for future renwals. Even the $10 or $15 plans will get that credit if you use autopay. It's got nothing to do with any data.
08-15-2019 06:06 PM
And if you are worried about overages... Your in luck, no overages with PM. So just enable your data and MMS away!
08-15-2019 06:04 PM - edited 08-15-2019 06:04 PM
