Port over link
kiki_
Hi,
I just signed up for PM and want to port over my koodo prepaid phone number.
Does anyone have the link to do that?
Thanks!
@RossN wrote:
@kiki_ hi you go into or create your self serve account if you haven't done so already and go under change phone number it can be done there good luck and welcome to PM sorry didnt see the pre paid koodo you must contact a moderator for that
Koodo prepaid porting cannot be done in the self serve.  Time to read over the knowledge base articles.
GR
@kiki_  while you wait keep using your Koodo Sim card until the port is complete! Make  sure you keep the Koodo account active also!
Dunkman
@kiki_
Koodo prepaid and Public mobile share the same back end.
You will need to contact moderator to complete port.  Expect 1-2 day wait time.
Send a private message to moderator through the following link :
RossN
@kiki_ hi you go into or create your self serve account if you haven't done so already and go under change phone number it can be done there good luck and welcome to PM sorry didnt see the pre paid koodo you must contact a moderator for that https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
