03-23-2020 06:40 PM - edited 01-05-2022 10:03 AM
I was wondering what the cost is if I go over my 250mb limit.
I cant log into my account currently, to add more data.
03-23-2020 08:03 PM
Options to get more data:
1. If your current data limit does not meet your 30 days' need, you may change a plan with more data. You can do the plan from self-serve. You get your data back immediately with plan change.
2. If you want to renew the same plan early, you need to create a moderator support ticket using the ? button at the bottom right hand corner of this page. Moderator wait time is 2 days. If your next renewal date is 2 days away, you may just on data diet for a few days until after renewal.
3. You can buy data add-ons $30 1GB data or $10 200MB data. Expensive option
03-23-2020 06:46 PM - edited 03-23-2020 06:53 PM
@armstrong123, make sure you take advantage of FREE wi-fi hotspots such as Shaw, who has over 100,000 across Canada. Read this post for more freebies, who doesn't like free stuff!
03-23-2020 06:42 PM
Thanks
03-23-2020 06:41 PM - edited 03-23-2020 06:42 PM
@armstrong123 a big whopping $0. There are no overages here. It will just stop working. Welcome to PM.
