100 minutes Canada wide talk plan
07-11-2023 04:15 PM
This plan includes 100 minutes per month. Why do I have no minutes included this month?
Plans
07-11-2023 10:53 PM
There are already a lot of replies with good answers. I'll add mine if it's cool. The Public Mobile website can, for some reason, create cache and history issues in your browser. Open your browser settings and clear your history. Then clear your cache. Close your browser and log back in and check your account for minutes. I'm pretty sure they'll be there. If not, at least your wife won't see what sites you've been to recently. 🙂
07-11-2023 05:48 PM
Thanks.
07-11-2023 05:39 PM
there was some network issues earlier today but is now resolved, please first reboot your phone and try again
Also, try this if that does not work
- try change the Preferred network type or network mode to 3G only or WCDMA only and see if it works
- Try to click Reset All Networks and see if it helps
- and do you have another phone to test the PM sim ? just to make sure it is not a device problem. Also, that can force a sim card re-provision and it could resolve the problem
- Also, try the phone in another area if possible, it could be just a local network outage
07-11-2023 05:37 PM
@LJ65 Yes you should get 100 mins out going every 30 days . Maybe ask support what’s going on
message support directly
while your already here and logged in the community you can send a private message To CS_Agents click
VVVVV Link below VVVVV
07-11-2023 05:36 PM
I have tried the $5 add on mins but that has not come through. Account is in good standing. Phone is iphone6.
07-11-2023 05:33 PM
100 out going minutes per 30 day , correct
i have been with Public Mobile for years and have never had a problem. What has changed?
07-11-2023 05:30 PM
Yes
07-11-2023 05:29 PM
I am in a new pay month and have not used any minutes. Should have 100 minutes per month
07-11-2023 05:25 PM
if you have the $15 / 30 Day plan you may have used all 100 outgoing minutes already. I have the same plan and have also purchased the $5 / 500 Minutes of Canada wide Calling add-on. If you run outta regular plan minutes (like you seem to have), then those add-on minutes will take over until next regular plan renewal OR you buy a new plan. If you don't use all the add-on minutes, they stay on your account until you use 'em up...even if that takes several months or more.
07-11-2023 05:21 PM
Maybe you used them all. Do the refresh icons shown in the images provided. Or is your account active? Or are you getting some other message?
07-11-2023 05:18 PM
you probly mean $15 / 30 days, huh !!
07-11-2023 04:20 PM - edited 07-11-2023 05:20 PM
