$10 voucher only added $5
06-05-2022 04:01 AM
I bought a $10 voucher to add on data. I added the voucher after selecting the option to get 200gb for $5 and it only added the $5 not the additional $5
Add-Ons
06-05-2022 02:51 PM
06-05-2022 11:20 AM
Just an aside you can still register for autopay and not actually have autopay used, for example you can still put vouchers on your account to cover the upcoming renewal. That way you will be saving another 2/month so 5 altogether. Just a suggestion
06-05-2022 11:19 AM
@Lissa1 wrote:Thank you. I just checked my transactions and it says that I added on 2 — 2mb add one for $10. So the transactions went through. However, I haven’t been able to get in the internet without wifi. And my phone just notified me that I’ve used 75% of my data. I just topped up my plan on the 1st and I purchased the add on, not even 12 hours ago so there is no way I’ve used that much data.
@Lissa1 Login to My Account and check if you see a line about the 2GB Data under My Data & Add-on section in the Overview page.
Also, looks like you are using Android phone, go to your Mobile Data Usage page, change the "start billing cycle on" to June 4 (or 4th day of each month), to see the usage since June 4rd. This will show you what the device recorded your data usage since and which app used the data and how much. This can confirm if you really used the 2GB in just 1 day
06-05-2022 10:58 AM - edited 06-05-2022 10:59 AM
Can you provide images of your payment history and overview page both without identifiable information.
Perhaps you have settings on the phone to switch to mobile data when wifi is weak or out of range. Perhaps settings also to update the OS and apps on any internet connection.
The phone notified you? Or a text from 611? Images always help.
06-05-2022 10:58 AM
06-05-2022 10:54 AM
06-05-2022 10:49 AM
@Lissa1 Can you login to My Account and check the Transaction log? it is best and will show clearly the transaction entries
06-05-2022 10:48 AM
I should have explained further, my bad.
I added on the $10 voucher over the phone, then selected data add on option 1 - 200 megabites for $5 ..after doing so, the operator dude said “thanks. Let’s finish your purchase” then the phone went blank. I called back and there was only $8 (I had $3 credit) but no data on my phone. There should have been $13 if no data was added. Im staying at my friends for the weekend, without internet and my phone just notified me that I’ve used 75% of my data. I just topped off my monthly plan last week, AND I purchased an add on, so I should not be out of data yet.
06-05-2022 08:59 AM
@Lissa1 - check your transaction history, do you see the $10 voucher amount listed there:
https://selfserve.publicmobile.ca/Overview/payment/Payment-History/
Also, was your plan working before you added this, with calls and texting? Just wondering if your plan was in suspended/nonpay status? Addons will only work on an Active plan.
06-05-2022 04:04 AM
@Lissa1 wrote:I bought a $10 voucher to add on data. I added the voucher after selecting the option to get 200gb for $5 and it only added the $5 not the additional $5
It only added $5 because the other $5 paid for the 200MB add-on.
