03-24-2019 08:55 PM - edited 01-05-2022 03:55 AM
03-24-2019 10:33 PM
@uoft The remaining balance won't expired until you used them up. But you may want to think about to change the plan $25 with 1GB (that is with autopay special) and you have unlimited Canada-wide calls and texts for international. Or even the $15 plan has 100 minutes Canada-wide calls and unlimited international texting and 250MB data if you have autopay setup.
Just think about what you actually need.
03-24-2019 08:57 PM
@uoft a écrit :I purchased 1 GB for $30 on Nov 21, 2018. I used it reraly. On Mar 21, 2019. there is one usage for 760MB. Will the add on expire after 4 months?
There is no expiration date for the add-on.
03-24-2019 08:57 PM
@uoft wrote:I purchased 1 GB for $30 on Nov 21, 2018. I used it reraly. On Mar 21, 2019. there is one usage for 760MB. Will the add on expire after 4 months?
No time limit...just consumption.
Maybe an OS update. Or apps.
03-24-2019 08:57 PM
The add-on won't disappear from your account if there is data usage remaining as long as your Public Mobile account stays open.
