Reply
Highlighted
Re: [Issue Resolved] Plan data not renewing
Thank you
Highlighted
would you able to solve the issue of inability to sent text as well. thank you
Highlighted
Re: [Fix in progress] Plan data not renewing
I have this issue since May 1st. No response so far.
Highlighted
 My data still does now work. I have rebooted and made sure my data in
Is active in phone settings.
Highlighted
Hope this gets fixed as soon as possible
Highlighted
By the solution being implemented, does this mean that the issue is currently solved? Or on its way to be, with a specific solution identified? I am still unable to use my plan data (May 12) although I am able to use some Add-On data.
Highlighted
If you have Data issue, It may be related to APN setting.
Highlighted
Apn settings don't change suddenly.
And yes I have verified the settings . Everything is unchanged
Highlighted
@ashiskhadka51 @dmannk @Jessmir88
According to Public mobile, this issue is "resolved."  If you are still having issues with plan data not renewing, you should contact moderator.
Send a private message to moderator through the following link :
Highlighted
I have sent and no response after a week.
