04-19-2019 01:52 PM - edited 01-05-2022 04:28 AM
Hello,
I've been fiddling with my flip phone for about 20-30 minutes it seems and cannot get the thing to receive test pictures. It's not a huge deal, I only wish to use my phone as a phone but the simple fact that I cannot get something to work as intended irks me.
The pictures are side ways, which I did not intend.
MODEL Samsung SGH C414
04-19-2019 02:24 PM - edited 04-19-2019 02:28 PM
You need to enable the data on your flip phone first in order to send and receive picture MMS. I got an Alcatel Go Flip for my mother to use with PM $10 50/50 plan. The APN was setup automatically after installing PM SIM card and after phone restart.
04-19-2019 02:17 PM
@Barryere wrote:Hello,
You need to be in data mode whether or not you have data in your services.
Then:
Find your phone on this list:
Officially Recognized APN Reference
If your phone isn't there maybe these might work:
APN Settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN type: default,mms,agps,supl,fota,hipri,dun
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
04-19-2019 02:09 PM - edited 04-19-2019 02:13 PM
You need to make sure data is turned on by going to the Connectivity settings menu. In Idle mode, press OK, select Settings, the select Connectivity. You should be able to make various changes from there, including turning on data.
As for the APN settings not sure for that phone do you have Data included as part of your plan? If no, then no need to set that up.
