Motorola G8 power lite
Cathy2007
I’m looking at this phone, is anyone else using it on PM? Working OK?
Degen4Life
Yes it will. I purchased it off Amazon and am using it now with PM. Only issue I had was setting up the PM Data by creating a new APN Setting. I had to do the following...
Steps: Order a new PM SIM,  insert the freedom mobile SIM, manually create a new setting within the APN menu with the public mobile parameters, remove the freedom SIM, insert the public mobile SIM.
I found these steps on another thread but am unsure how to link that post here. This fixed my issue though.
Staliger
@Cathy2007 Yes, it will work with PM perfectly. Go for it.
