04-10-2023 01:00 PM
I transferred and activated my phone service on Apr 5, 2023, Unfortunately I had been unable to connect to
the Public Mobile Network. The Data Usage on my phone on Apr 10 shows "0 B of data used". I had reset the systom as per the recommendations of Public. However, it's still not working. My phone is Moto G8 Power Lite. It has been working fine with the previous service provider.
04-23-2023 08:36 PM
The problem has been tackled with by replacing my cell phone. The old phone (Motorola Moto G8 Power Lite, Model XT2055-2) may not be compatible with the Public Mobile Network. The new phone (Samsung Galaxy A52, Model A525M/DS) is now working very well with the Public mobile network. Thanks to all the friends for your kind responses.
04-11-2023 04:12 AM - edited 04-11-2023 04:19 AM
If at first you don't succeed try, try again. System wouldn't let me post.....?
Can you send/recieve MMS? Have you enabled mobile data on your phone? According to the specs I found for your phone you are fully compatible with public mobile.
I suspect @gpixel is correct and you need to edit your APN. If your phone won't let you edit your APN because it's greyed out first check and see if you can update your OS software (Android9?) and see if it changes your ability to edit your APN. Compare it to the following APN settings on my moto g7+......
Now can I post?
Edit:
The spam filter will not let me post the compatibility bands or the APN. The community sure is Grrrreat!! 🐯
Edit:
Compare your APN to this one....
Edit:
Specs for your phone....
https://www.devicespecifications.com/en/model/ac33534a
After you compare your APN and can edit then...
Save and reboot your phone. If you still cannot edit your APN your old freedom Sim card will come in handy (Do not throw it away as it will help you update your APN now and in the future?) We can talk you thru that if needed or you can get customer support to text you a configuration file to update your carrier file.
Welcome to Public Mobile!
04-10-2023 09:29 PM
HI @alberty305
do you see a screen asking you to login when you tried to access internet via your browser? If you see the login screen, it means you used up your data
are you on $15 plan with 250Mb of data? That is not a lot of data and can easily be all used up quickly
Please check My Account again using Incognito/Private/Secret browser mode and check your data again, maybe it is not showing 0Mb data used any more
04-10-2023 09:18 PM
you probably need to edit your apn settings
04-10-2023 03:18 PM
@alberty305 it is weird why it shows not connecting but you are getting voice call
Can you post a screenshot?
at the same time, open ticket with PM support and have them to reprovision the sim
04-10-2023 03:16 PM
I changed the Preferred Network Type to 3G. Not working. Still cannot connect to Public Mobile Network.
04-10-2023 03:09 PM - edited 04-10-2023 03:11 PM
I can't find much about your phone, but look like this is what it has for LTE BOLD are compatible ones.
LTE Cat4 (Bands 1, 3, 5, 7, 8, 20) TD-LTE (Bands 38, 39, 40, 41)
And FYI PM needs these bands on LTE
4G/LTE: B2 (1900), B4/B66 (2100 or 1700), B5 (850), B7 (2600), B12/B17 (700), B13 (700), B29 (700-Suppl. DL), B30 (2300)
Any phone should ideally have 3G B2, B5 and LTE B4 (or B66 instead of B4), B12 (or B17 instead of B12) for minimum coverage.
04-10-2023 03:06 PM
@alberty305 it could be a phone compatibility issue on LTE. Try to change your Preferred network type or Network mode to 3G only and see if it works
04-10-2023 03:01 PM
Yes, I can make or receive phone calls on PM sim.
My phone is Moto G8 Power Lite. Don't know where to find the model.
04-10-2023 02:54 PM - edited 04-10-2023 02:55 PM
@alberty305 your 1 and 2 confirmed that sim is in fact working but not understand why you said 3 saying the sim is not connected to PM. If sim not connected, voice won't work
Two questions, you can receive incoming calls on your PM sim?
and what brand and model your phone??
and can you post a screenshot showing the error about not connecting to network?
04-10-2023 02:49 PM
1. Yes, the voice service is working.
2. The phone is showing connected to Public Network.
3. I inserted the SIM card into another phone. Same problem - could not connect to mobile network.
4. I also put back the original SIM card from the previous service provider (Freedom). It shows cannot connect to any network, meaning this SIM card (phone no) had been unlocked by the previous service provider?
04-10-2023 01:10 PM
@alberty305 Check your phone's network settings, make sure it's connect to Public Mobile or manually connect to Public Mobile.
04-10-2023 01:05 PM
If you replied to the text confirming you are porting over to PM with YES within the 90 minute time frame then porting was successfully then reboot your phone by powering off the phone then back on.
If that didn’t work, try resetting the Network on your phone.
If all fails then contact a CS_Agent to look into it for you. It could be a backend/provisional issue.
04-10-2023 01:04 PM
@alberty305 is the voice service working?
does the phone showing not connected to P network?
could be just a sim card provisioning problem, it is an error fix for PM support. Please open ticket with them
1. Please open ticket via Chatbot (requires access to My Account): click this Chatbot Ticket Link
Then click "Click here to submit a ticket ↗" to open the ticket submission page
Next, enter your Community login, then enter your question. Finally use My Account login or 4 digits PIN to validate.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
04-10-2023 01:02 PM
Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
Confirm first if your account is active and how many data allowance you have.
