wrong selection during plan change
DevgunJD
Hello, I did plan changes today, by mistake I selected 'change now' than 'change plan at renewal'. I did it for two accounts and both plans just got renewed. Can I reverse this change or someone can assist to set changes on renewal.
sorry to hear that.  Yes, a wrong Changr Now request usually cannot be reversed  😞
DevgunJD
Thanks for your guidance Mr. Handy1 Tried with CS_Agent but no luck as changes are immediate.
@DevgunJD  You can try to submit ticket with support and see if they can help reverse this for you . But PM is pre paid and typically no refunds . Best of luck
send a  private message   To CS_Agents
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
