07-29-2019 04:00 PM - edited 01-05-2022 06:10 AM
Need to top up when I enter a voucher it says can not process. I have tried 3 different vouchers
07-29-2019 06:10 PM
@roderickbirdsto wrote:Need to top up when I enter a voucher it says can not process. I have tried 3 different vouchers
Until the Public Mobile voucher glitch is addressed...have a look at recharge.com. You can recharge your account using on-line voucher provider...with a small cost.
Let us know if you opt for this method.
07-29-2019 04:37 PM
@roderickbirdsto Based on this thread https://productioncommunity.publicmobile.ca/t5/Getting-Started/Vouchers-not-working/m-p/401849, you need to plan on at least 3 days without service. ![]()
Meanwhile, if you need to make calls try an application like that from fongo.com; SMS also available for about $3. It provides free calling across Canada from wherever you are connected to wifi (or on cellular data). Even though I have never needed it in 4 years, it's my backup service for these situations.
07-29-2019 04:07 PM
Unfortunately, there's a lot of problems with vouchers lately, you'll need to send a private message to Moderator_Team here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
It might take a few days to hear back from them according to other posters with similar problems.
07-29-2019 04:05 PM
Did you try Self serve and 611?
