where do I find my SIM card pin to make a payment
bz2
@bz2
You created the PIN when you activated your SIM. You can login to your account and look under Profile. There you can change it if you wish.
darlicious
@bz2
You chose a 4 digit account PIN # at activation. Otherwise you will find it in your self serve account's profile....or rather you can reset it there. If you have been here awhile you may have received a text from pm on 611 with it on the day you activated.
bz2
Where do I find a pin #, asking *611 when, I want to make a payment over my cell.
