voicemail envelope information
carter29
 hello hello when I access my voicemail at always gives me the phone number or the person's name that's leaving me the voicemail.
 is there a is there a setting to eliminate this so it just goes straight to the voicemail message?
@Nezgar wrote:
Yes I just doctored this image to show the "Playback Preferences" menu options. 😁
Great work @Nezgar . I'm not sure why the others couldn't just try it. I got into the voicemail and went down those options and oh there it is caller id.
Some time ago I had thought I heard something along the lines of verbose or short. Maybe that was for much older systems back in the day.
Nezgar
There's an option under the Playback Preferences in the link from Triguy. Have a look at that. It says something about the caller id.
Dunkman
@carter29
Not sure whether you can change that feature.
Here is some more information about voicemail features from Public mobile:
https://www.publicmobile.ca/en/bc/get-help/articles?category=phones&subcategory=voicemail-features
gblackma
@carter29  I'm calling in the expert. @Nezgar . Please help. Thanks.
Triguy
I don't think that it is possible.
You can try checking the menu options
https://www.publicmobile.ca/en/bc/get-help/articles/change-your-voicemail-language
