voice mail?
liban961
Hi
i receive voice mail message from public mobile every single day
i dont have voice mail now
 do i need it? it is free?
if my cellphone is off  and someone call me what happen? will i receive voice mail message from caller?
thank you
7 REPLIES 7
@srlawren wrote:
@will13am wrote:
@liban961, are you referring to voice mail notification?  If you have a voicemail that has not been heard, the notification stays.  If you don't like voicemail, tell your contacts not to leave one.
@will13am I usually suggest people dial into their voicemail and record and activate an "extended absence greeting".  When that greeting is active, nobody can leave you a message.  They hear the extended absence greeting you recorded, and then the call ends.  So I suggest people leave a personal message asking folks to text them instead, or something along those lines.
Great idea.  I think I am going to recite the first two chapters of Dostoyevsky's crime and punishment instead of a standard greeting.  That should eliminate all voice messages.  Now if only Public Mobile would implement voice mail like Google, then I won't mind.  I get an email with voice clip and text translation.
Speaking of voice mail, mobile syrup is doing a poll on voice mail.  So far, about 1/3 of respondents actually leave voice messages all the time.
https://mobilesyrup.com/2017/10/02/poll-do-you-leave-a-voicemail/
srlawren
Acekiller
if you don't have VM you wouldn't have received the VM from PM.
imm1304
Hey @liban961,
If you never set up your voicemail, you should not be getting any voicemail notifications from PM.  Do you not remembering setting up your voicemail??
As others have said, voicemail is free and people will be directed to your voicemail if you can't answer the call or if your phone is switeched off or your phone is not getting signal.
will13am
torontokris
@liban961
Voicemail is included for free on all current Public Mobile plans . According to the PM website "All plans include Voicemail and Call Display"
Yes if your phone is off you will still be able to recieve voicemail
Hope that helps
ShawnC13
@liban961, not sure what you mean about receiving a voicemail message from PM everyday?  Yes, voicemail is included in your plan.  Do you need it? Not sure that is for you to decide.
