06-24-2022 07:49 AM
The promo didnt add so I tried to submit ticket and created a community account. Logged into commmunity account and chated to SIMON chat bot. he said to submit ticket and when I tried it said to verify my account. I tried that and it said username error so now I cant submit ticket.
Service
06-24-2022 10:03 AM - edited 06-24-2022 10:04 AM
You can use a referral code and a promo code at the same time. The issue you had adding the promo code was probably the missing "S" in the promo code you tried to enter. It should have been 12MONTHS2GB not 12MONTH2GB. The $10 bonus referral credit will be added within 72 hours of activation.
When a referral code or promo code is accepted and added successfully you will see a checked box icon appear and the referral code and/or promo code promotion will appear below the appropriate box.
06-24-2022 08:29 AM
@Krayd wrote:Yes, the username for community and self serve account are different. I used the community one to verify account.
@Krayd So, you are all good in terms of verifying account?
When you open ticket, usually it will first ask you for the Community account. Then after you fill in all the info, it will ask you for Self-Serve My Account login/password or 4 digits PIN before you can submit the ticket. It is a bit confusing
06-24-2022 08:24 AM
06-24-2022 08:23 AM
Yes, 12 MONTH 2GB promo and did register email first. i did use refer a friend as well though. Maybe you can't have promo and refer a friend??
06-24-2022 08:11 AM
@Krayd what promo code are you refering to?was it the 2gb for 12 months? did you register your email for the promo?
06-24-2022 07:54 AM
@Krayd hi if you are having issues with Simon try this if you are having issues with Simon you can send private message to a CS Agent here: https://bit.ly/2GGCJzH
06-24-2022 07:52 AM - edited 06-24-2022 07:53 AM
@Krayd just to clarify, the username for My Account would be different from your name here. Community and Self serve My Account are 2 different systems.
Community username for you is Krayd but the My Account username will be your email address used for activation. Also the password for the 2 systems could be different.
You can try to use Forgot Password link ( https://selfserve.publicmobile.ca/forgot-password/ )on the My Account page to try to reset it by putting different email address.
if still unable to reset, please open ticket with PM Support
1. For faster response (2-48 hours), Click on the bubble in the lower right to request CS Agent assistance, or use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
