2 weeks ago
2 weeks ago
@Krayd I suspect the porting was never completed. Did you reply the text from Rogers to approve the porting? did you reply within 90 mins?
I will private message you a phone number. Check your Community inbox, envelope icon on the top right. Call them, it's live support and they can advise if porting was indeed completed or re-trigger the process
2 weeks ago
@Krayd hello did you port your number from another provider if so did you receive port request?
2 weeks ago
@Krayd are you new to PM and requested porting number into PM? If so, did you receive a text from your old provider and reply YES within 90 mins to approve the porting? This is a critical step in porting, if you missed it , let us know and we can advise
or if you are existing PM subscriber for long time, then It could be network issue in your area.
Try to reboot your phone first and see if it works
If not, try to reseat your sim card ( power down the phone, then take the sim out for a minute before you put it back and power it up again)
If it still no receiving incoming calls , try to change the network to 3G Only (or WCDMA only) and see if it helps
2 weeks ago
Yes, I bought sim card for PM and activated it exactly how it said. Now only certain people can text and call and other people texts wont get through and calls go straight to answering machine. I tried to get help but I needed to join the community first. I opened a community account and talked to the chat box that said I needed to open a ticket. I tried to submit ticket and it wanted me to verify my account before submiting ticket. I tried to log in and it says USERNAME error. I tried to get a verifying code sent to phone but texts wont come through.
This Public Mobile is ruining my life and sinking my personal business and I have spent hours each day trying to fix these massive issues
2 weeks ago
@Krayd So, you are getting some incoming calls and text now but not all
Again, how long you have joined PM?
Also, do you think you can find out the carrier used by those who cannot reach you? If it is just from one particular carrier, it could be an issue on that end. I have seen that before.
Since you have trouble with open ticket with Chatbot, please open ticket with PM using direct message, it is easier with less login confusion
Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
2 weeks ago
I switched from Rogers to PM on the 21st of June. have reseated SIM card and reset phone about a dozen times since then. I don't know what carrier they are on because I cannot reach them. When people call it goes straight to answering machine.
2 weeks ago
@Krayd But the critical question is , you really got incoming calls at all? if you never got any incoming calls, then the porting wasn't completed. Try to call it from a landline and see if the call reaches you. If it goes to voicemail, check if it is a Rogers VM or PM VM.
Or if you still have the Rogers SIM, put it back to a phone and see if that Rogers SIM can make outgoing calls or receive incoming
2 weeks ago
No incoming calls. goes straight to answering machine.
I tried to send a text to verify phone and no text will come through.
2 weeks ago
2 weeks ago
I ported number from Rogers. I called Rogers and cancelled my service after I switched the sim cards and activated PM
