Thursday
Friend call me and it went in Voicemail directly without ring. how do i solve this problem ?
Thursday
Did you just port in your number?
Thursday - last edited Thursday
When you activate your account, you can call out and text immediately. Incoming calls take 30 minutes to an hour in most cases to kick in.
Thursday
@pcprajapati check/try:
Could be just network related, and hopefully will clear up soon if none of the above helps.
Thursday
It could be some network issue.
First, try to reboot your phone and see if it works
If not, try to reseat your sim card, power down the phone, then take the sim out for a minute before you put it back and power it up again
If it still no receiving incoming calls , try to change the network to 3G Only (or WCDMA only) and see if it helps
Friday
nop, I'm using since 2018
Friday
DND settings?
Or was your phone in use when he called...thus a voicemail?
Blocked?
Friday
HI @pcprajapati I has been over 24 hours, you still have the problem today?
did you try to reboot your phone? did you try changing your network to 3G Only (some phones call it WCDMA only or HSPA Only)
And you can make outgoing calls?
