use more than one US roaming addon concurrently?
10-14-2019 10:24 PM - edited 01-05-2022 07:34 AM
10-14-2019 10:44 PM
@canadave Yes you can but I would recommend purchasing the talk & text bundle and the 1GB data that way you save a $1.
10-14-2019 10:42 PM
@canadave wrote:Can I buy three US roaming addons (unlimited calling, unlimited texting, and 1GB data addon) and use them all at the same time?
Why not just buy 2. Unlimited US calling and Texting an then the data addon saves $1
10-14-2019 10:26 PM - edited 10-14-2019 10:27 PM
You can have more than one U.S. roaming add-on but each has to be different. You cannot have duplciates.
Nope...you'll have to get it again, as it expires...but give it 24 hours after each has expired.
