08-21-2020 12:39 PM - edited 01-05-2022 12:37 PM
Is there a way for me to search ONLY web (data) activity on usage through my online account? I've tried sorting column headers but that doesn't seem to help.
My Account
08-21-2020 02:58 PM
Maybe I'll get someone I know to help me with this spreadsheet - she's the Queen of spreadsheets. 🤫
08-21-2020 02:13 PM
@HALIMACS wrote:Is there a way for me to search ONLY web (data) activity on usage through my online account? I've tried sorting column headers but that doesn't seem to help.
Hello @HALIMACS ,
I would suggest picking the date range you are looking for below:
then sort the "Date/Time" column by A-Z or Z-A, this sorting does work it just looks off because it has the format of DD/MM/YYYY.
Then you can click the "Data Usage" column to group it. You will have to copy and paste into excel to see totals.
It is not the most user friendly method, I KNOW, but it may get you what you are looking for.
Good Luck!
08-21-2020 12:43 PM - edited 08-21-2020 03:02 PM
@HALIMACS Yes I believe you can if you click on the sub headings, ie: call type, originating#, data usage. Click My Usage under Change my Plan option of the overview page.
Edit: then click data usage and it sorts all your recent data usage.
Second edit to correct the sub headings names.
08-21-2020 12:42 PM
I don't think it is possible due usage being based on date rather than type.
08-21-2020 12:40 PM
I haven't found a way, I think you are just going to have to go through all of your usage and take out the information you want.
