usa roaming dropping calls
guy-ffc
i have multiple roaming added and cannot make a call past one min long
xxxxxxxxxxx how do I get this fixed?
edited by computergeek541: phone number removed
 @guy-ffc : This is almost always a problem of having multiple same-feature add-ons. You can't stack up a talk add-on on an existing talk add-on. Each add-on needs to run out the clock too. ie 10-24 hour periods. If you wish to re-buy then you need to contact the CSA's or wait another 24 hours.
You can buy the different data buckets if you've used all of one but the same 10-24 hour period stands to not buy the same one.
@guy-ffc   PM partnered with AT&T and T-Mobile for US roaming, which network you are connected to?  did you try both and same issue?
Dunkman
@guy-ffc
Are you in the US right now?  Which roaming packages do you have?  Is that the only phone number that is affected?  Does text and data work?
If you have multiple add ons with overlapping features, that might cause a glitch in the system and contacting CSA is necessary to fix the issues.
Triguy
https://www.publicmobile.ca/en/on/get-help/articles/us-roaming
If you still need assistance then submit a ticket.
Here’s when and how to contact our Customer Support Agents:
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get started.
  • Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work.
