3 weeks ago
3 weeks ago
The phone is Artfone 4G Volte . The area is Ontario.
3 weeks ago
"dropping from 4G to 3G" during calls is normal if your phone is not compatible with PM's VoLTE system
What phone do you have? Which province you are in?
First, use the IMEI checker on this page to see if your phone is compatible with PM's VoLTE network: https://www.publicmobile.ca/en/on/get-help/articles/volte
If it is not compatible with PM's VoLTE, then your phone had been using 3G for voice and is now affected by the 3G Network Shutdown that has just started in Manitoba:
https://www.publicmobile.ca/en/get-help/articles/3g-shutdown
If you’re using a 3G-only device, your phone will stop working after these dates:
Manitoba (Rural): January 12, 2026
Manitoba (Urban : Winnipeg & Brandon): Starting March 31, 2026
National: Starting March 1, 2027
If the lack of VoLTE support is what affecting your voice calls, there is really nothing much you can do other than getting a phone that is compatible with PM's VoLTE network. Hare are couple choices of phones that will work:
But generally most major brands of phones released after 2024 and are designed and sold for the Canadian market should work. If you are unsure whether a particular phone will work, share the model here and we can help
