01-06-2023 12:29 PM
01-06-2023 12:55 PM
@Meow- A couple things, the T-Mobile 2G is for talk. It would otherwise stay on LTE (as usually set). Having roaming on is only for data. This customer didn't say they got data.
01-06-2023 12:51 PM
Check your account to see if you can see that add-on there. Are you currently in USA?
According to Public Mobile:
PM will have T-mobile 2G network for US roaming. Try to manually connect to T-mobile and have roaming on.
Voice and SMS text will still work.
Data will work on LTE, but will switch over to 2G to make a call.
However, the quality of service will vary depending on the different coverage areas when roaming in the USA.
01-06-2023 12:47 PM
@hycm53- They didn't say they got data. The roaming switch is also only for data.
01-06-2023 12:38 PM
@Dent1 wrote:I paid for my us roamimg talk/text addon, it is not activated
Turn data on and roam on. Manual to connect to T-Mobile .
01-06-2023 12:32 PM - edited 01-06-2023 12:33 PM
Is this a re-buy from having one previously? Roaming only works with T-Mobile. Make sure you're connected to them.
Adding - and you're in the states right?
