us roaming plan
johnpublic
I just bought the usa roaming plan  $20 . Do I have to activate it when I go to my account and plan add on I do not see it?
johnpublic
I will check tomorrow when I cross the boarder.. hope it works!
johnpublic
I did try that already I will try one more time see what happens
cellphoneuser1
It was activated when you bought the add-on. The 15 days started immediately.  Click on the page refreshing arrow in Self Serve.  If the add-on isn't there, log out and log in again using incognito mode.
@johnpublic
Refresh your browser and see if the US roaming is shown in the Plan & Add-on section. Also you will be charged so go to the Payment and see if you were charged.
If both are shown then go to the settings and see if roaming is enable then to cellular network and connect to T-Mobile.
