01-29-2023 03:04 PM - last edited on 01-30-2023 01:25 AM by computergeek541
New SIM card works on the old phone but it doesn’t on a new one.
01-30-2023 02:02 AM - edited 01-30-2023 02:03 AM
Go to Settings>General>About then scroll down to Carrier Lock and it will show the carrier that locked the phone.
If it is unlocked, it will show No SIM Restrictions.
Is it an American phone because carrier in Canada are not allowed to lock phones after December 1, 2017.
The iPhone 11 was released on 2019.
01-30-2023 01:26 AM
@Mircia0611 wrote:It says the SIM card is not supported under activation policy
Although you were told otherwise, that error message means that unfortunatley, it's not unlocked.
01-29-2023 08:04 PM
Glad you got it sorted out.!! Have a wonderful evening!!
01-29-2023 08:00 PM
Do you get any type of error message when you put the sim card into the new phone?
01-29-2023 03:23 PM
01-29-2023 03:22 PM
It’s unlocked, it was checked but Apple store. It’s a brand new iPhone 11
01-29-2023 03:21 PM
Is your phone locked? Contact your previous provider to unlock it for you. You will need your imei number, dial *#06# to get it.
01-29-2023 03:06 PM - edited 01-29-2023 03:07 PM
Try rebooting your phone by powering the phone off by holding down the phone button then power back on if your new phone is unlocked.
What does your phone show on the top?
01-29-2023 03:05 PM - edited 01-29-2023 03:09 PM
@Mircia0611 Check device
Check the Status of Your Device in Canada | https:/
edit also dose the the new phone use different size SIM card for the SIM tray
