10-07-2024 01:53 PM
I need to update the address on my account in which they are sending my "new" sim card to.
10-07-2024 01:59 PM
@cwilliams27 You can update the your address in your account profile page . If you have any trouble ask support to help you do so
10-07-2024 01:55 PM
hi @cwilliams27
if you have already order the sim, you will need to as PM support agent to trace the order. So, please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
if you have not ordered it yet, i suggest you to buy in person at a Telus or Koodo store. problem with order from PM could take 3 days to 3 weeks
but if you need to update your address, login My Account, Profile, then Manage EverSafe ID and update the address there
