3 hours ago
Hello Team,
My current phone died, and I had eSIM on it now my temporary old phone does not support eSIMs. I bought SIM card from Tellus and have changed the card number on my account, but the SIM is not active. Do i have to wait or there is something else I need to do that is missing here?
Thanks a bunch for quick response.
3 hours ago
Update:
All good, now, had to wait for half an hour I guess. It just got activated. Thanks everyone.
3 hours ago
HI @Vito24
did you try reboot your device once more as suggested above?
3 hours ago
@Vito24 First try rebooting the phone see if that helps
3 hours ago
Hi Handy1. Thanks for quick response, I did exactly as you described, changed the number to new SIM card number but nothing happened. Will submit a ticket now!
3 hours ago
@Vito24 You need a new Public mobile SIM card and log into your account profile page and sim swap the number like this
SIM SWAPPING profile tabs
This can also be done on the app also , if you have any issues logging in you can ask support to sim swap the number for you
3 hours ago
HI @Vito24
you login to My account or on the app to update the sim card? usually it will work after a device reboot. try once more
if same, please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
