12-12-2022 09:24 PM
Hi,
I am unable to receive phone calls but can make calls. I also unable to login to self serve to verify my account, When I try to reset the password it said "failed to reset password". Please help.
12-12-2022 10:08 PM
@softech Believe it or not, not everyone looks at your copy and paste posts. Ha ha
12-12-2022 09:59 PM - edited 12-12-2022 10:01 PM
@emily2110316 wrote:I am not a new member. I have been calling-receiving for many months now. please helpp.
two things to try
1. Reseat your sim card. Power off the phone, take the sim card out for a minute, then put it back in and power up the phone
2. Try changing the phone's Preferred network type to 3G ONLY and check if the phone can connect to PM network and if it can receive incoming calls
@Quigley you actually ddin't need to make update to your post after mine. Turned out OP wasn't porting in new number. LoL
12-12-2022 09:55 PM
You should try to contact a Public Mobile Customer Support Agent and have them look into your sim card and provisions.
Use the Chatbot Simon to get a service ticket started first.
12-12-2022 09:51 PM
12-12-2022 09:26 PM
did you just joined PM and requested Porting in your old number as well?
If you did did you recieve from your old provider a porting authentication text and did you reply YES within 90 min?.
If you are not receiving calls and text on your PM sim card and can only make outgoing calls, then you might have missed the step and hence porting was not completed
There is a number to call to talk to live support, they can re-trigger the process for you. I will message the number to you via the Community inbox. Check the envelope icon on top right. Call them and get it fixe
12-12-2022 09:25 PM - edited 12-12-2022 09:30 PM
To login to your account try using a browser in incognito or private mode first.
Try again.
If you did everything right for your port request, then you'll just have to wait a little longer until your port request is completed.
Maybe restart your phone once in a while to see if all your services work.
