unable to log in our accounts
BethMcDonald
the passwords or e-mails for both my husbands and my accounts for some reason are not being accepted
2 REPLIES 2
hairbag1
You did use a different email address for each account...right ? You must not use the same email for each account.
hi @BethMcDonald
did you try using the Forgot Password link to reset password.  And try using Incognito/private/secret mode on your browser to login My Account, or try using the PM app (logoff the app first and log back in)
if same, you will need to ask PM support agent to sort it out.  You can submit  ticket by direct message:
