03-19-2018 04:51 PM - edited 01-04-2022 03:45 PM
i will travel to tronto, i am in montreal, my plan is talk & text,
what addon i have to buy ?
1) for incoming calls
2) for outgoing to montreal
3) outgoing to tronto
4) text
5) mms
thanks for helping
03-19-2018 07:26 PM - edited 03-19-2018 07:28 PM
@Rabbiwrote:i will travel to tronto, i am in montreal, my plan is talk & text,
4) text
5) mms
thanks for helping
If you have a Canada-wide talk calling plan, no add-on is required for any of those services.
However, if you only have province-wide calling included in your plan:
1) You are supposed to have to buy a long distance minute bundle add-on for any incoming phone to work ( with Montreal phone number while in Toronto), but for some strange reason, Public Mobiles seems to have been letting this slide for quite some time.
2) you need a long distance add on (either long ditsance option will be fine)
3) and 4) no add-on required
03-19-2018 05:11 PM
thanks for helping me
03-19-2018 05:06 PM - edited 03-19-2018 05:07 PM
@Rabbi, If you have a canada wide plan, then you don't need any add-on. If you have a provincial talk plan, then you would need a long distance plan 200 or 400 minutes ($8 or $15) in order to be able to call back to Montreal, and in order to be able to receive calls (although some people have been able to receive calls when out of province without an add-on). While in Toronto, you can call TO Toronto without a LD add-on.
Texts (and MMS) are automatically canada wide.
