11-29-2023 06:09 PM - last edited on 11-29-2023 06:39 PM by computergeek541
11-29-2023 06:20 PM - edited 11-29-2023 06:21 PM
Hi @Ayanna,
The only SIM card that can be swapped from one phone to another is a Physical SIM. The eSIM is unique to the one phone unfortunately. This means that you will have to purchase a new SIM no matter what. That being said, you might as well invest in a Physical SIM so that you can re-use it as many times as you want.
You can order SIM cards several ways.
11-29-2023 06:13 PM - edited 12-08-2023 12:39 PM
HI @Ayanna
sorry, no eSIM transfer betwen phones. Most carriers have this policy. You need to rebuy a new one
Since you need to rebuy new, why not change it back to physical?. With physical sim, you can easily switch it between phones for FREE.
You can get a physical sim from Telus or Koodo stores ($10) or online at Amazon ($5)
but if you are staying with eSIM, download the PM app on the new phone. Buy from the Subscription & addon page (you might need to expand the menu by clicking on the circle with a + at the bottom left). When you are on that page, scroll down and click Shop Sim card
11-29-2023 06:11 PM
NO. That is WHY physical SIM is way better than eSIM.
11-29-2023 06:10 PM
You can't. You will have to purchase another esim for your phone.
