transfer to another provider
Chels99
I would like to transfer to another provider but it is not working as I am unable to receive texts in the country that I am currently in.
@Chels99 wrote:
okay, thank you.
I decided to stay where I am for 6 mths so that sucks for me lol. Do you think I could get an Esim for the country I am in through airalo to give me service? and then switch over using that ?
@Chels99
It will be expensive for any Canadian mobile company to international roam for six months.  It will be cheaper to get a domestic SIM card and use while traveling.
If you don't care about your Canadian number, just unsubscribed from preauthorized payments and let your phone number expire.  After 90 days suspension, your account will be closed forever.
If you want to keep your Canadian number, then there a few things that you can do.
https://productioncommunity.publicmobile.ca/t5/Get-Support/Extended-Absence/m-p/142735#M129086
The hassle of getting a foreign SIM card is that you won't be able to receive 2FA texts from Canadian companies like banks, etc.
Chels99
okay, thank you.
Dunkman
@Chels99
It is more difficult to port to another provider once you are outside Canada.
You will need to contact customer service agent to see if that is possible.  You may need to wait until you come back to Canada.
Send a private message to CSA through the following link :
HI @Chels99
is your PM account still active?  It must be active for the number to port out
and you can receive text from others and just not the one from PM?  Ask your new carrier to resend the port
if still not receiving it, CS agent can check.  please submit a ticket with CS Agent here:
hairbag1
@Chels99
PM messages will only be recieved in Canada or US with correct add-on.
