transfer problem
3 weeks ago
- last edited
3 weeks ago
computergeek541
i want to transfer my public moblie to fizz.It shows that publicMobile seems to have restrictions that prevent me from transferring to fizz. what can i do?thank u!
Other
3 weeks ago
thank u !i have sent the message through this link and hope they will reply soon.thank u for your reply.
3 weeks ago
@Frankzhoucheng There's no impediment from Public Mobile's end that I can think of since your plan is still active. You can private message Public Mobile support and see what they say, use this link
You do still have your Public Mobile sim in the phone to authorize the transfer when you get the SMS from them? You have to do that within 90 minutes of receiving it.
3 weeks ago
thank u for your reply.my PM is still cative.I have talked with fizz and they said that pM have some limited,suggest me to contact PM.
3 weeks ago - last edited 3 weeks ago
@Frankzhoucheng Normally the onus is on the receiving carrier to initiate the port but you have to leave your PM sim in the phone to receive the SMS to authorize release of the number. This can only happen if your PM account is still active as already mentioned. What exactly is happening when you, or Fizz, try to transfer the number? Also, is your phone compatible with Fizz after they start decomissioning 3G in July - list here
3 weeks ago
PN does not have restriction with porting out. you can port out as long as account is active
However, some numbers cannot be ported to particular provider due to technical problems , an issue with the other provider and not Pm's
Call Fizz and confirm if your number can be ported over to them. even it cannot be ported to Fizz, your number could still be ported to other providers
3 weeks ago
@Frankzhoucheng wrote:i want to transfer my public moblie to fizz.It shows that publicMobile seems to have restrictions that prevent me from transferring to fizz. what can i do?thank u!
Hello @Frankzhoucheng
First and foremost, your Public Mobile account must be active. If it is, you should be getting a text from Public Mobile asking your permission to port. If you are not receiving the porting request, you can reach out to Public Mobile by creating a ticket informing them permission is granted to port.
Please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket.
