an hour ago
It has been more than 5 hours and transfer is not done. I see SOS only in network and restarts didn’t help.
an hour ago
hi @Mattsu
first, can you confirm if you have receive a text from PC and asking for your approval with the port? and your PC sim still working?
And for the PM sim, try remove the old carrier sim card, or if it the old carrier sim is esim, disable it from Sim Manager or Settings->Cellular
Then put the PM sim card in the phone, or if eSIM, you should be good
Next, go to Sim Manager or Settings->Cellular and check if PM sim is showing there. Make sure the Public Mobile sim is enabled , or Turn on this line option is toggled on. Also, change the label to Primary
Reboot your phone and Reset network settings and test and confirm if all work or let us know of if any the following does not work: inbound and outbound calls, inbound and outbound text, mobile data.
if the sim not connecting, ask PM support agent to help. You can submit ticket by direct message:
