Activating sim
Bridgette1
15 REPLIES 15
@Bridgette1 wrote:
  • Thanks I’ll try that. Virgin have stopped my old  service.
you need to call Virgin to resume the service back so you can request porting number.  Or ask Virgin to see if they are willing to take your verbal approval for the porting
After Virgin agrees, or you have the Virgin service resumed, then ask PM to re-request the porting.  You might want to message PM.   Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
@Bridgette1   If you have stopped your Virgin service then your number can't be transferred.  Just choose a new PM number and put in your Public Mobile sim and restart the phone.  If you really want to transfer your Virgin number you will  have to talk to Virgin.  If you need customer service send a private message using this link
An agent will reply at the envelope icon top right of this page or tap your avatar for messages.
Bridgette1
Bridgette1
Yes
@Bridgette1   Customer service is all online by messaging with Public Mobile.  If you need phone support it might not be the carrier for you.  Have you already signed up for a Public Mobile account?
Bridgette1
I received a new hard sim from Public. I haven’t done anything with old virgin account or my phone. I’m not good with chat. I’d prefer to talk to someone.
@Bridgette1   If you already replied Yes to the port authorization from your old carrier, and the old carrier sim now no longer works, you don't need to wait to be told to install the Public Mobile sim, just put it in the phone and restart it.
Bridgette1
I receive a hard sim from Public.
@Bridgette1 wrote:
I’ve been waiting 4 hours for direction to install my new sim and transfer my old number
Did you buy a hard sim or esim for your new plan ? During the activation process, you're given opportunity to port your old number in to Public Mobile...but your old account must still be active so don't cancel it.
Bridgette1
Bridgette1
When can I install my new sim?
Bridgette1
I’m using the downloaded app.
@Bridgette1
Do you need instructions?
hairbag1
@Bridgette1
You must download the Public Mobile app to your cell… then you can complete the activation process succsessfully.
slusagm
what is the problem? tell us more
