Hi, I activated my public mobile line yesterday. I am happy with the service so wanted to port in my number from videotron today. When I select videotron, it says 'previous service provider is invalid'. I tried clicking on other service providers and the error doesn't appear and allows you to enter IMEI or account number. When videotron is selected, the fields remain greyed out.
If I select Fizz, the error doesn't appear. Since Fizz is a subsidiary of videotron, should I be try the port with that option?
Thanks.
