Porting issue
Deaton5858
Hello,
Ive been having issues porting my number over, I've filled out the request form, and no lock. its way pas the 30 mins quoted its been like 10 hours
@Deaton5858 wrote:
Yes  and I replied yes confirming it, about a minute later you texted me saying porting issues and will be in contact
You are talking to customers like yourself. PM texted you. So you will have to either send private message to agent or call number others provided.
@Deaton5858 they won't contact you themselves,  you have to contact them and see what happened.
I will message you the porting support team.  Check your Community Inbox,  them call them
Deaton5858
Dunkman
@Deaton5858
Did you get a port confirmation text from your old carrier?
I will private message you the Telus porting phone number.  Only used for porting issues.
