top up wont work
naseemsh
i key in PIN for top up it says I ve 35 balance but still no service no data
2 REPLIES 2
maximum_gato
@softech
Since when? Fixing 611? Payments made thru the 611/IVR system should automatically reactivate the account as long as they equal or exceed the plan amount and the account is not suspended via lost/stolen.
@naseemsh
Does any of the above apply to your situation?
@naseemsh   you used *611 to top up?
sometimes it take longer for *611 to reactivate the plan
Wait another 15 mins and reboot the phone
and best is to login My Account using Incognito mode to confirm the account status
