04-12-2022 12:00 PM
04-12-2022 08:51 PM
@RobertVincent - You can only transfer your number over from Virgin if the account is active. If your Virgin account is not active, reactivate it with them, then proceed to continue to restart the porting process.
Porting your phone number from another cell provider could take a few hours to complete the port.
Using the other cell provider's SIM you should be still receiving calls on it, until the port completes.
Make sure you do not cancel your previous provider's services.
Incoming calls are usually the last to port over.
If issues porting or transferring a number to Public Mobile, and it has been over the allotted time it usually takes to complete, submit a ticket with customer support agents for porting related inquiries here for help: https://widget.telus.tiia.ai/chatbot.html?botId=ZJkWuVb7Hp6EEcTIZKMZbvLwuDV&duid=1ml7MK2dvkmM37lFcEM...
See helpful info. here: https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
04-12-2022 12:01 PM
@RobertVincent do you need to port from Virgin to PM but you missed the text from Virgin? Yes, you can ask PM to retrigger the process. There is a number you need to call and they can assist. I will message you the number. Please check Community inbox on the top right, envelope icon
