04-26-2023 12:45 PM
I just received my new SIM card, but I found the SIM card can't be inserted into my iPhone. How to do right now? Do I need to request a new SIM card?
04-26-2023 02:16 PM
@hTideGnow wrote:HI @LitlLdy
the iSolution, buy a new adaptor, that's why that want. LoL
@hTideGnow , I know, as if the phones don’t cost enough as it is! The power adapter alone is expensive but no clue how I would plug in to a computer for iTunes now! My old iPhone & iPad came with the lightening cable, power adapter & earphones! Crazy! 🙄 But that’s a different post, not PM related! 🤣
04-26-2023 02:11 PM
04-26-2023 01:38 PM - edited 04-26-2023 01:40 PM
@hTideGnow wrote:HI@Josephzheng keep an eye of the notch on one corner of the sim tray. Some iphone, you actually see the chip facing up, which is different from some older iPhone
@hTideGnow , I noticed that recently when switching from an old 6S iPhone to my new 14 Pro iPhone! At 1st I thought something was wrong 🤣!
Of course they also changed the lightening cable that comes with the iPhone (both ends & no usb end anymore) so it can no longer be plugged into the previous power adapter to charge it & they do not send one with it so you can’t charge the iPhone! With no more usb end it can no longer be plugged into a power bar nor a computer to use with iTunes! Seems wasteful to me!
04-26-2023 01:07 PM
04-26-2023 01:02 PM - edited 04-26-2023 01:04 PM
look closely to see how to adjust and size the sim correctly for your cell phone...
added...
OR are you having trouble finding / opening the sim slot ?
If so, let us know which iPhone you have.
04-26-2023 01:02 PM
It has to fit. SIM cards are 3-in-1 so you remove pieces you do not need
04-26-2023 12:46 PM
@Josephzheng , the SIM card breaks down into 3 different sizes. Please take a very close look at the cutouts.
