04-26-2023 01:54 PM - last edited on 04-26-2023 04:52 PM by computergeek541
04-26-2023 02:14 PM
Hi @Pettman1967 Where the call from ?
but you should be able to receive incoming calls regardless of the location and country. It is usually the calling side where the problem is
04-26-2023 02:06 PM
@Pettman1967 did you just port your number into Public Mobile? If so, how long has it been?
Also, you sure your friend used the correct dialing sequence to call you?
04-26-2023 02:04 PM
you should be able to receive calls from anywhere on planet Earth. Look in settings on your phone to see if you've blocked LD calls. Maybe Parental Controls has a setting blocking LD calls.
04-26-2023 01:56 PM
@Pettman1967 What happens on the callers side? You're receiving local calls OK? SMS and data is working OK?
04-26-2023 01:56 PM
Maybe callers do not dial all digits required? Can you receive ANY calls at all?
Can YOU call them?
Is your account active?
