12-31-2019 07:50 AM - edited 01-05-2022 08:48 AM
not recieving text messages or calls , can make a call and send text , not sure what is going on , we are new to public mobile
Joining Public
12-31-2019 08:35 AM - edited 12-31-2019 10:10 AM
@506georgie I hope time or perhaps porting help has already fixed your issue. However, you said you did not know what was happening. I'm assuming here that you did bring your number over from another carrier and you ported your number on activation.
Your old provider still holds your number. PM sets up your account with a kind of duplicate number which will only allow you use data and to text/call out with your PM sim as your incoming texts/calls are still coming into your old provider.
Three things to bare in mind:
a. Your old sim card should still work in your phone until your number port completes.
b. When your port completes, your old providers sim will stop working, and your PM sim should be fully functional.
c. You may find that there may be a short period of time, where calls will not ring on either provider's sim; instead they go straight to your old provider's voicemail. This should figure itself out within 30 minutes.
Just switch sims and reboot your phone, if necessary.
12-31-2019 07:55 AM
Have you ported a number recently from another carrier? This is normal. You can call out right away, but you have to wait anywhere from a few minutes to 4 hours for your incoming calls and texts to come in.
If you don't receive a text or call within 4 hrs,
Explain your issue to SIMON, seen below:
Use as few words as possible to allow the BOT to understand. Answer his questions until you get here:
Click on "Submit a ticket" and the Moderator team will respond to your concern, usually within 48 hours.
Alternatively, you may send a private message to moderator through the following link :
Contact @Moderator_Team
About @Moderator_Team
Moderator Hours
Monday-Friday: 8AM- 12AM EST
Saturday & Sunday: 8AM-10PM EST
12-31-2019 07:51 AM
Try the simplest thing first...reboot your phone
