09-22-2023 12:44 AM
My data stopped working for me today. But I logged into check it and get an add-on (HATE that it no longer rolls over!!) and my usage said I still had half of my 1GB left. What gives? Why is my data not working?
09-22-2023 07:53 AM - edited 09-22-2023 07:53 AM
Morning @rainsmell
When you log into your account, while on overview, click on this little counter clockwise updater to get a more accurate amount. You can also clear the cache on your browser and then try again.
09-22-2023 03:05 AM
@rainsmell Did you try logging in using incognito/private browsing mode? There is a refresh button to load your current usage. Try that. Usually, the text is pretty accurate. If you have another 1GB add-on saparate from your plan allowance, it should work. Is your calling and texting services
