09-14-2023 08:37 AM - last edited on 09-14-2023 03:59 PM by computergeek541
I bought 90 day plan for $102 but my credit card is billed with $111.87. Why? How can I get this resolved with a customer service agent? Many thanks
09-22-2023 07:52 AM - edited 09-22-2023 08:50 AM
self solution removed
09-22-2023 06:51 AM
Thanks a lot everyone who replied. The issue is now solved😀❤
Thank you,
Champa
09-14-2023 12:37 PM
09-14-2023 11:51 AM
09-14-2023 11:49 AM - edited 09-14-2023 11:50 AM
Why only $111.87 ?-----You should have been charged $115.26 if you live in Ontario.
09-14-2023 09:50 AM
@abtest Still better then the maritimes 😞
09-14-2023 09:49 AM
09-14-2023 09:16 AM
09-14-2023 08:39 AM - edited 09-14-2023 08:56 AM
@champa1 Yes this is normal because it’s $102 plus tax so you get 60GB for 90 days
Adding it should be a lil more then that , I’m assuming you have some rewards that went against that also like loyalty friend referral or auto pay @champa1 that or this is Quebec or Alberta number you have which is less tax then rest of the country
