Added US Data Addon by mistake
Garthox
@CS_Agent
is there a way to fix the mistake I made? I used all my points to try and add extra data to my account. I added US Roaming when I only needed regular data added to my account.
Garthox
Thanks, I did try to submit a ticket, but that was not working and pointed me to the community. I’ll try again.
@Garthox  .please submit ticket with support and ask if they can reverse this for you
send a  private message   To CS_Agents click
Chalupa_Batman
Morning @Garthox
You can reach a CS Agent via this link. Please check your mailbox in the top right corner for their reply.
