switching to promotion plan
03-07-2018 11:34 PM - edited 01-04-2022 03:40 PM
03-08-2018 12:34 AM - edited 03-08-2018 12:36 AM
@nullset If you are an existing user, you can make changes to your plan from your self-serve account.
If you are looking to activate for the first time, You need to activate the sim here: https://activate.publicmobile.ca/
On the Plan selection step, you will be able to build the $50/6GB plan.
