3-Month plans?
GiraffeHat1
Hey guys,
There used to be a way to switch to a 3-month plan for a slight discount to the rate... Is that limited to certain times or plans?
I'm interested in switching to that, but I can't find the option anymore.
Thanks for your help!
8 REPLIES 8
GiraffeHat1
Don't worry, I'm VERY cautious about not going to a plan that will cost more. 😂
It would feel like I'm losing ground if I picked a plan that costs more than my current one.
I'm just being greedy and trying to min/max my plan. Thanks for your advice @hairbag1 !
@GiraffeHat1
@GiraffeHat1 wrote:
I kind of thought it was a modifier of your current plan rather than it's own separate plan. If I have a really nice boxing day plan, does that mean it's unlikely to have a matching 90 day plan?
if you currently have a great plan that meets your needs / budget...just hang on to it. Right now there's no 90 days plans to even consider. If you keep watching your plan menu from time-to-time, you'll see plans will evolve. Remember that if you do change plans, you probably won't be able to go back to the Boxing Day plan you have right now.
GiraffeHat1
@slusagm @hTideGnow
Alright, that's a bit disappointing. I thought I'd get a free $4 discount but it looks like I'll be waiting until next Black Friday or another major sale.
Thank you both for your help! Have a nice weekend!
HI @GiraffeHat1
no, it won't be built on your current plan.
yes, as you said, those 90 plans would be new plans.  If 90 days plans come back, they will be different plans, but could be better than your current one 🙂
GiraffeHat1
slusagm
no, currently no plan has the 3-month or 90 days option.  Only 30 days and no 90 days plan to change to
hi @GiraffeHat1
the 90 days plans come and go.   At the moment, there is no 90 days choices.  Cannot tell if it will come back soon.  But you have to keep an eye
