support
JPSMITH
I have been trying to get help to activate a new account with no response from the agents since Saturday.  I have tried opening a new ticket but it dpoes n
HI @JPSMITH
you check the Community inbox for their response? they usually reply within 2 hour and a bit and always within the same day
But what error you got? which stage you got stuck? share more info and we can try to help
And at the same time, submit a ticket with again again:
JRod
@JPSMITH
Is there any chance you haven’t tried opening the account through the app? If you haven’t I would try that first. If not you can contact support here:
Please click this link below to message customer service:
Keep an eye on your mailbox here as that is where your reply will come in (envelope icon on desktop, click your avatar icon in the corner and then click messages if on mobile).
@JPSMITH  You need the app to activate have you tried using the app yet , but here’s direct link to support
send a  private message   To CS_Agents click
